A/A Fuel GTX
- WI & AZ
- Electrician
Does anyone know when it became a violation to cover knob and tube in attics with insulation?
What I thought, but I have been wrong before.I would figure that it was always a violation to insulate around K+T.
Not to my knowledge, but it sure happens alot.What about K&T in walls with insulation. Is that legit?
Used to be K&T never got covered because it was on inside walls and people didn't insulate their attic. Then by the time insulation became the norm we stopped installing K&T.
Then came blown-in insulation and nobody questioned whether or not they could cover K&T. Well, maybe not nobody, but usually not insulation installers who weren't versed in electrical installations.
Now we have to sign a document stating there is no K&T before they'll install blown-in insulation.
Makes we really wonder why anyone in a cold climate on the east would keep K&T
I'm thinking the main reason for not covering K & T in attics is the fact that it could be easily damaged by someone crawling around up there when concealed and not so much the thermal issue. I've got a house I was called to that was built in the 40's. It has been sold and the home inspection states that K & T is present. There is blown insulation throughout. It doesn't say anything about the insulation issue but the agent had me verify that the K & T was present. So I go up into the attic and find that yes, it is there and yes it is covered in insulation. So how do I play this? I told the agent that yes, I can remove the K & T but the blown in insulation would have to be removed first. I'm the only one in this situation who knows this is a violation of current standards but is it possible that it was legal back when it was done? The inspection report simply states that the K & T is there and goes no further. I do a lot of work for real estate agents correcting issues the home inspectors write up. I go into these places and only address the things on the inspection report but I could usually spend days correcting violations the home inspector missed. Where does a guy stop........
They no longer insulate around K&T, after a couple fires it was obvious to them.
I would leave K & T in a finished plaster ceiling going to that antique fixture . The room has that turn of the century look . Maybe that 2 Button Antique Switch . I would not leave it anywhere else .
Don
I wonder if the fires were caused by contact with insulation or improper modifications to the K & T. I've seen some nasty taps over the years.
Assuming that it is in its original condition and was correctly installed, I don't see K&T as being any more dangerous than NM, even where it is covered in thermal insulation assuming that the OCPD is per Table 310.15(B)(16). The original OCPD for K&T was often per the "free air" ampacity table.As iwire said, it's not REALLY dangerous, just a little bit.
