Again we can not determine the correct OCPD with the information provided.
Finally, some sanity here.
The OP failed to state where he is and what his supply voltage is. Granted, this is primarily a North American based forum since it s based on the US NEC, but we all know that people from other countries frequent here. Without that additional info, there is no way to determine anything useful here with certainty, beyond what Mr. Bill said. If the supply is 120V, it is the higher number, if it is 240V, it is the lower number.
I see a lot of newer appliances now coming with this kind of rating, because they are essentially saying that they are suitable for 120
OR 240V supply, 50/60Hz, making them universally applicable to markets in the US and other parts of the world. What these manufacturers are doing now is running the internal motors, controls, elements etc. on DC and using a universal switching power supply that can take any input voltage from 180 - 265VAC. So in order to not have a 10 inch square nameplate to state every possible combination of voltages and current, they just state the kW rating and leave it to the installer to figure it out.
So to be absolutely sure, the OP must determine the supply voltage AND the power input configuration of the appliance; i.e. 1 hot line and a neutral coming into it or two hot lines, with or without a neutral? If there is only 1 hot line coming in, and he is in North America where that would be 120V, then he has to use the higher numbers. But if it takes 2 hot lines (or can be configured to do so), and he is in NA, then he can use the 240V values. But if he is in an IEC country, then 1 hot line and a neutral would be 230V ad he would use the lower values.
Bottom line, not enough info.
