I'm electrical engineer in Costa Rica and I designed a building with 50 condos. My interpretation of Article 210.8 of the NEC is that all the receptacles of the Small appliances branch circuit in Kitchen Countertop must be GFCI. The contractor has a U.S. assistant electrician and he said that only the first receptacle of branch circuit must be GFCI because others will be protected downstream and that is the way as you do always in the United States. I do not agree with that point of view because if GFCI receptacle fails the other downstream receptacles will remain unprotected. I know that in the past 5 years there have been many failures in GFCI receptacles outlets. Contractor and electrician want to reduce receptacles costs.Please I would like to know the opinion of you.Please.
