- Massachusetts
Re: Kitchen island receptacles
Originally posted by georgestolz:
Where is the lesser favored one?![]()
Being under an overhang would preclude it from serving the countertop. I wasn't going down the road you're thinking of, I think.Originally posted by iwire:
IMO an outlet installed on an island that qualifies as serving the counter top will have to be considered as serving the countertop.
Bob, I agree 100% with that statement. The receptacle we are discussing does not qualify as serving the countertop, because it is below a too-wide overhang.Originally posted by iwire:
The receptacles are not unsafe. One receptacle is required in a specific location. I believe this is due to the length of the factory cords on appliances. Basically 12' below the countertop is equivalent to under an overhang of 6". Not exactly, but basically. Using any island receptacle may be unsafe, but as long as they are all GFCI protected, they are all equally safe. The receptacle is not unsafe, but certain uses might be. Do you think that the NEC deems it unsafe because a child is more likely to pull down a crock pot plugged into a receptacle mounted under a 7'" overhang and 34" above the floor than a child would be to pull down one mounted 24" above the floor under no overhang? Or is it more dangerous because a homeowner might break out an extension cord to use one instead of the other. Either way I don't think that the code wording support the "unsafe argument".Originally posted by charlie b:
The key is this: If a receptacle is installed anywhere on an island, there is no way for the homeowner to know whether or not it is intended to serve the countertop surface. The homeowner is not going to notice that a receptacle is 15 inches below the countertop or that a receptacle is under an 8 inch overhang, and therefore know that they should not plug a crock pot into that receptacle. The homeowner must be free to presume that any receptacle on an island can be used to power something on the countertop. Therefore, we must install receptacles with that possibility in mind. If we do otherwise, we create an unsafe condition. I don't believe the code was intended to allow us to create an unsafe condition.
I think not. I see a 1 foot wall space that does not require a receptacle. I also see a peninsula that only requires one receptacle, and that one does not have to be on the side next to the patio door. That is part of the discussion in "that other thread," if I could ever find it.Originally posted by jim dungar:The 3' wide fixed pane of the patio door is located 1' away from the edge of the peninsula. This gives a wall space of 4', so a general use wall receptacle is required.
The "unsafe" part that I see is not related to GFCI protection, nor to a child pulling on the cord. It is you (or any other person) sitting on a bar stool, with your legs under that 12 inch overhang, and with a crock pot plugged into the receptacle near or below your knees. As you rotate the barstool in preparation for standing up, your legs contact and pull the cord, and the crock pot lands on your lap. To prevent such an accident, we should not put a receptacle under that 12 inch overhang.Originally posted by j_erickson: The receptacles are not unsafe. One receptacle is required in a specific location. . . . Using any island receptacle may be unsafe, but as long as they are all GFCI protected, they are all equally safe. . . . Do you think that the NEC deems it unsafe because a child is more likely to pull down a crock pot . . . .
Charlie, while I don't disagree that this may pose a hazard if used in this manner, I still do not see an NEC article prohibiting this installation. If the required receptacle is in place, then homeowner must be held accountable for engaging in an unsafe practiceOriginally posted by charlie b:
Now I'm not sure I understood your description. Let me see if this is what you meant:Originally posted by jim dungar:210.52(A)(2)(2) requires the door panel to be counted when determining wall space, therefore a receptacle is required in the 1' wall.
If you put a receptacle on the 1 foot wide section of wall (not required, but it is allowed), then it is not serving "wall counter spaces." So no, I would say that 210.52(C) does not apply.Originally posted by jim dungar: Would you say 210.52(C) applies to this receptacle.
