agolestani
- United States
Hi all,
I've done many projects in the past where we run pvc conduit into the ground from the main, and uf after the elbow underground in a 12" trench, (In LA so no frostline). The uf goes to a shed or maybe an outdoor kitchen and is connected there to a GFCI/swith combo box to account for the disconnect and GFCI requirements. From there, everything is run within the shed or kitchen frame with NM-B or whatever may be the case.
My question is regarding more rigorous landscaping electrical, and more specifically an MWBC. Pergola lighting, patio step lighting, and some electrical outlets is the task. After the UF comes out of the ground to the first GFCI Outlet switch, it reburied to reach the next junction near a pergola post or patio step light.
Is it okay to rebury wire after the initial gfci/switch box? Or is there another proper method?
Thanks in advanced.
Thanks in advanced.
