Large Pull Box
mstrlucky74
NJ
If you had a conduit bank with (11) 4",(2) 3",(2) 3-1/2",(2) 2" & (1) 2-1/2" and it was a straight horizontal run of about 300' what are your options for a pull point? Would a huge pull box be practical or would you use 'C' condulets? Thanks.
augie47
Tennessee
Unless I had more than 360? bend in a run, my option would be pull straight thru.
infinity
New Jersey
Journeyman Electrician
Pu straight thru without any condulet or box? No code violation due to distance without a pull point?
No, the pull point is required when you exceed 360? of bends in the run. And if needed, forget C conduit bodies on large conduit as they do not satisfy the 8X requirement for a pull point. Also if the run is vertical you will need support points for the conductors.
mstrlucky74
NJ
This is a horizontal run. I know about the vert supports. Can you explain the C condulet and not satisfying the 8x rule?
So you agree to pull straight thru for the scenario I laid out in my first post? Thanks
Fulthrotl
~Autocorrect is My Worst Enema.~
you price eleven 4" C condulets, and then allow for access to all of them on a rack.
when you find those condulets, can you post the catalog number here, so we all won't
have to look it up? thanks.
edit:
note to self.... randy, you are an idiot.
"A great place to start the explanation is to review an earlier post where you posed the same question:
http://forums.mikeholt.com/showthrea...light=condulet"
crap! he trolled me again! i'd forgotten this post entirely,
and i even replied to the stupid thing.
he trolled me TWICE, with the same bait.
mstrlucky74
NJ
edit:
Agree with note to self!
augie47
Tennessee
since mstrlucky has an explanation link (again), I am closing the thread.
