goldstar
 - New Jersey
 - Electrical Contractor
I was just starting to come around to Al's way of thinking when I read this :
Unless I missed this somewhere in this thread, doesn't installing an AFCI receptacle downstream of the over-current device violate the exceptions to 210.12(A)?
			Don't you think the CMP's should have thought of this back in 2011 when this section of the Code first appeared ? How can you write Code when products intended for use aren't even commercially available ? Then suddenly when one or a few manufacturers produce a product (that BTW is hard to find) to fit this section, EI's from coast to coast instantly find reasons to fail a job based on this section.(3) A receptacle protected by a listed combination type arc-fault circuit-interrupter circuit breaker is not commercially available.
(4) There is no GFCI/AFCI combination receptacle commercially available.
