readydave8
re member
- Clarkesville, Georgia
- electrician
So smaller wire may reduce amount of light flicker, but increase duration?
Possibly.So smaller wire may reduce amount of light flicker, but increase duration?
I have lost submersibles due to load shock during starting on the shaft to pump splines a few times just at my place. Soft starting reduces this problem.This process has been used for submersible wells for some time. They can exert quite a bit of stress on the drop pipe at startup so VD is beneficial.
