I have several LED 120v lights on a circuit being fed by a 15 amp SQ D Homeline combo AFCI/GFCI breaker. The breaker holds until I cut on the lights and then it trips. There is 10 LED lights on the circuit so I thought that might be the problem so I tried it just one LED light and the breaker still trips. I tried several different breakers that work ok on other circuits so I know the breakers are working properly. ANy ideas how to fix this problem? Thanks!
