- Massachusetts
I'm on board with most everything in it, but when you're talking about covered terminals on a transformer installed above a caninet, there are "approved" scenarios which are far more likely to see trouble.
Like a table lamp without a bulb in it. What's to keep Joe Schmoe from sticking his finger in it? Or more probable would be his kid sticking fingers in it.
There is no practical way to guard the lamp socket until they give up on the use Edison base lamps altogether.
On the other hand there are very easy ways to enclose your line voltage connections to this power supply.
Here is a contactor with guarded terminals, would you install this without an enclosure?
