lightolier 1103r
sparky1118
Massachusetts
Master Electrician
Has anyone heard of an LED retro trim for a 6" lightolier with the floating socket?
Sent from my SM-G975U using Tapatalk
peter d
New England
They exist but are very expensive. Your best bet is to install Sylvania's retrofit sleeve for the Lightolier housings and use a regular LED trim.
sparky1118
Massachusetts
Master Electrician
I am wondering if a 6" LED wafer light will work with the existing hole. Since there isn't a can and just a housing
peter d
New England
The Sylvania retrofit rings are about $5 at the wholesaler and install faster than those Halo retrofit cans.
sparky1118
Massachusetts
Master Electrician
Thank you. I was able to use a Westinghouse retro fit LED trim. How I made it work was I bent the clamps down about 90⁰ and they held perfectly snug!
