kp542
- Pittsburgh, PA, USA
Would the circuit feeding a lobster tank in a seafood restaurant / food procurement store require GFCI protection?
In my opinion, if it's not in a commercial kitchen, no.
-Hal
Couldn't it be considered a "wet" area ?
When I suggested that it might be considered a wet area I was thinking more of a fish market than a retail store.No different than an aquarium in one’s living room.
Just to be safe I would boil them.
Is the tank likely to become energized in any way is a question that needs answered IMO. There may be aeration pump, but it don't have to be in/on the tank, just an air tube to the tank.get the melted butter!!!!
serious note
required? idk
I would install one
people standing on ground reaching into a tank of water
Thanks for that information, I had no idea what a GFCI was:blink:easy to err on the side of safety in this case, low cost and essy to implement
likely some lights around or in the tank
remote pump could fail and conduct via water/tubing
https://www.bulkreefsupply.com/aquarium-safety
GFCI Protection:
All of your equipment should be GFCI protected. GFCI stands for Ground Fault Circuit Interrupt. You may be familiar with them, or it may sound like an entirely foreign concept. You probably use them at least a few times every day. You most commonly see these in the form of an outlet in your kitchen and bathrooms. They are the outlets that have a test and a reset button on them (usually between the two outlets).
Grounding Probes:
Grounding probes are a metal probe that mounts into the aquarium and connects your aquarium to ground via the electrical system. They plug into a regular outlet but only the grounding pin is actually wired to the probe. Electricity takes the path of least resistance to ground. If there was power source in the tank (say a light fell in) the current should go through the grounding probe rather then you, and trip the GFCI in the process. A grounding probe should also cause the GFCI to trip as soon as a problem presents itself as it has a route to ground, rather than waiting for someone to stick their hands in the tank (and then they are the route to ground).
GFCI Protection:
Grounding Probes:
Animal rights activists say the lobsters have rights !!! They should be GFCI protected before they get boiled or put on the barbie.I don't suppose the lobster cabal will be gaining a seat on cmp-2 anytime soon?
~RJ~
Animal rights activists say the lobsters have rights !!! They should be GFCI protected before they get boiled or put on the barbie.![]()
serious note
required? idk
I would install one
people standing on ground reaching into a tank of water.
An EGC on the equipment is a far better solution then any GFCI.
The way that is written dones't inspire confidence.
wrong
an egc does not prevent shock with a hi z fault
like a human at ~ 1000 ohm
google 'Dalziel' and learn something
gfci have saved alot of lives
your responses do not either lol
it was written by a guy who sells fish tanks
he wrote better about gfci than you could about fish tanks
and likely better than you could about gfci :lol:
