Location of receptacles for gas ranges
My partner was just turned down on inspection for the receptacle serving a gas range. The receptacle is on a dedicated 20 amp circuit located 2 feet below the top of the range, the inspector wants it moved 16" to the right of the stove, this will put it above the counter top and out of reach of the supplied cord, or into the cabinet where the cord would be subject to damage from pots, pans etc.
Is there any reason for this?
There is no such section in the NEC that would require compliance to this request (unless has something to do with the flood elevation in your juristiction).
