The real scoop on LOTO
I have to speak up here, because LOTO is a subject I know extremely well. Some of the posters here are on the right track, but some of you are not quite getting it.
For the most part OSHA requires that locks be removed by the authorized employee who installed them. The problems brought up here due to locks left on and having to be removed by someone else or cut off should not have happened. It is not the intent of the standard to be cutting off locks left and right due to convenience issues, as is discussed in OSHA's LOTO Preamble, which states:
"In paragraph (e)(3) of this Final Rule, OSHA is requiring that as a general rule, the authorized employee who affixes a lockout or tagout device is the only one allowed to remove it. OSHA believes that each employee must have the assurance that the device is in his/her control, and that it will not be removed by anyone else except in an emergency situation. The entire energy control program in this standard depends upon each employee recognizing and respecting another employee's lockout or tagout device. The servicing employee relies upon the fact that he/she applied the device, and assumes that it will remain on the equipment while he/she is exposed to the hazards of the servicing operation.
OSHA can envision very few instances which would justify one employee's removal of another's lockout or tagout device. However, in a true emergency, and not merely because the employee is not available, the employer may be able to demonstrate a need to remove an employee's lockout or tagout device. An exception to paragraph (e)(3) of the final rule is being provided to allow for such situations, and is discussed further below. OSHA emphasizes that removal of a personal lockout or tagout device by another person may not be based on convenience or simple unavailability of the employee. If a lockout or tagout device is attached, it is assumed that the employee who attached that device is engaged in servicing the equipment on which the device is in use, and that person is exposed to the hazards of reenergization. Therefore, as a general matter, the protection of that employee requires that he/she have complete control over his/her lockout or tagout device. Some modification of the general rule is warranted in the case of transfer of authority between shifts as discussed in paragraph (f)(4) below, and to a limited extent in group lockout or tagout, as discussed in paragraph (f)(3) below, both of which involve coordination of activities between servicing employees.
Under the exception to paragraph (e)(3), the employer may direct the removal of a lockout or tagout device by another employee only if the energy control program incorporates specific procedures and training for that purpose, and only where the employer can demonstrate that the alternative procedure will provide equivalent safety to having the employee remove his/her own device. The procedure must include, at a minimum, the following items: First, verification that the authorized employee is not at the facility; second, making all reasonable efforts to contact that employee to inform him/her that his/her device has been removed; and third, ensuring that employee knows of that device removal before he/she resumes work at the facility. These steps are necessary to ensure that the employee who is protected by the device is not exposed to energy hazards either at the time of its removal or afterwards."
Not removing the locks of other employees should not be an issue, either, if LOTO is performed properly. Per OSHA, Lockout/tagout applies to the servicing/maintenance or equipment or machinery, and the standard dictates that the locks and tags are only to be used for that purpose. At the end of the shift, or if the job is paused to order parts, or whatever, the LOTO should come off and go with the worker to whatever the next job he or she works on that requires it.
When the equipment is left in an unsafe condition as in some of the cases mentioned here, there is another OSHA standard that covers it. The standard on accident prevention signs and tags, 1910.145, states:
1910.145(f)(5)
"Danger tags. Danger tags shall be used in major hazard situations where an immediate hazard presents a threat of death or serious injury to employees. Danger tags shall be used only in these situations.
1910.145(f)(6)
Caution tags. Caution tags shall be used in minor hazard situations where a non-immediate or potential hazard or unsafe practice presents a lesser threat of employee injury. Caution tags shall be used only in these situations."
So, when there is a break in maintenance, LOTO should be removed, and if the equipment is left in a condition that would make it hazardous to the general public (not just dangerous to someone working on it, remember, any one working on it would have to LOTO it anyway), a Caution or Danger (non-LOTO) tag shall be applied. In the case that there is no personnel hazard but the equipment could be damaged if it were to be energized, a configuration type informational tag (non-OSHA regulated) can be used. For extra protection, any of these tags can be applied with what the ANSI LOTO standard refers to as a "service lock" which all members of a particular work crew have a key or the combination to. This allows for the configuration to be maintained, safely, and when work is to resume, the worker removes the service lock, applies his or her LOTO and verifies ZES before starting work. The ANSI standard goes into more detail on this than OSHA's standard does, even going as far as prescribing removal of the LOTO whenever the authorized employee must leave the building for any reason.
So, why is it so important to remove LOTO when you are no longer working on the equipment? Why not just leave it locked out and be extra safe?
It is OSHA's belief that the practice of leaving equipment locked out while it is not being worked on desensitizes employees to the meaning of the distinctive lock and tag. When this happens, and especially when the workers are already violating the standard by readily removing each others locks whether with a master key or by cutting them off, the entire meaning of LOTO is diluted and you have a recipe for disaster.
Where does OSHA spell this out in the LOTO standard, 1910.147?
That is the big problem; they don't; you have to read between the lines. Under 29 CFR 1910.147(c)(5)(ii), lockout/tagout devices ". . . shall not be used for other purposes; . . ." Additionally, 29 CFR 1910.147(a)(1)(i) states: "This standard covers the servicing and maintenance of machines and equipment in which the unexpected energization or start-up of the machines or equipment, or release of stored energy could cause injury to employees."
It would be hard to argue that the lock that was left on after the authorized employee has left for the day is being used to protect him during maintenance when no maintenance is occurring and he is at home sleeping.
I have seen OSHA inspectors write citations for LOTO locks and tags left in place when there is a break in maintenance.
As OSHA states in the LOTO Preamble, the provision to allow someone other that the authorized employee to remove the lockout/tagout is only for emergencies:
"This provision was intended to cover situations such as those that might arise from the sudden sickness or injury of an employee, key loss, or other emergency conditions."
If LOTO is removed when the authorized employee stops working on the equipment, these kinds of emergencies would be the only time there would be a need to remove someone else's LOTO.
Sorry to be so wordy.
