Electric-Light
Presently China dominates the LED industry. From components to manufacturing. The protocols around LEDs are still constantly changing. LED products are still quite fluid and standards are still developing and performance for many LED products are still unstable.
Lumen maintenance of conventional sources are backed by historical experience and data. LED lifetime is still significantly based on projection and faith.
There are three prevailing standards in use around LED luminaries.
LM-79: Brand new LED fixtures are rigged up in a lab and testing starts up. Data taken after fully warmed up. The outcome is entirely based on the performance on the evaluation day. Even the tests are often based in China and finding errors like unexplained notion like "12v 50Hz" on lab report for products sold under Philips label makes me doubt the competence of some tests.
LM-80 is a set of long term tests taken at 55C, 85C case temperature and one more temp of manufacturer's choice. Measurements taken every 1,000 hours or more for 6,000 or more hours. This is a component level test of the LED source which is not strictly defined.
TM-21 is an extrapolation (predicting forward) for up to six times the duration based on LM-80. A test batch of 10 for 5.5x extrapolation. 20 or more for 6x extrapolation. A small error can wildly skew the result just as when you're extending a line with a straight edge . The lab's room temperature is kept at 77F.
Overall I am not sure how meaningful it is. A 60W LED lamp bulb sold as general purpose 25,000 hour, for household use, suitable for use in totally enclosed fixture. Well. does this mean 25,000 to expected LED fading of 70% lumen maintenance in horizontal, open air use or 25,000 to 70% in a jelly jar? I'm pretty sure not the latter.
http://www.lightingfacts.com/downloads/lumen_maintenance_faq.pdf
So, when you see "lasts 10 years" means that they predict that it takes 10,950 hours at 3hrs/day for the LED elements inside to fade to 70%, but not take into account of other things.
You have probably seen a photographer use an umbrella to diffuse a flash. When you shoot light into an opal, some pass through but some scatter off the surface you aim the light into. This rebounce off white surfaces within the light fixture. So the conditions of white finish inside light fixtures absolutely matter. Yellowing will cause lumen loss and color shift.
This ETI SSL 546061XX LED luminary shows enough yellowing to infuse color into reflected light as well. This is an EnergyStar logo bearing, 830 lm, 11.5W 830lm LED surface mount luminaire advertised to last 35,000 to 50,000 hours depending on where you look.
The sample on left has perhaps 8,000 to 10,000 hours. Right has almost zero.
Consumer who choose to write reviews have written long before they have even reached 5% of rated life and good reviews have some purpose but they are not a good indication of long term durability.
The fixture is made of plastic and it showed obvious yellowing/browning. Some staining or scorching also visible inside the rubber goop within the LED elements. The white lacquer on circuit board/reflector, along with the fixture optics both show yellowing. LEDs generate white light by using a deep blue light to drive yellow phosphor applied directly onto the elements and the two mix together to form white. It is around 450 nm which has enough photon energy to be chemically active. This is why this spectrum of blue is used for industrial adhesive curing. The fixture claims 35,000 hour life but it has nothing close to that amount.
As this article shows, absorptions of blue photos can damage pigments over time. http://www.dailymail.co.uk/sciencet...ieces-artists-including-Van-Gogh-C-zanne.html
The red pigment in PVC wire inside this fixture sustained photon bombardment damage from exposure to intense LED light. You can see the slight difference in pigment damage along the hole where the light does not shine as strongly. The pigment with strong absorption of for blue left the pigment with strong blue absorption bleached out. The slight color difference in plastic frame on two units is due to discoloration from heat.
Thermal discoloration in general on plastic components as well as deposited capacitor fluid outgas on part of the ballast cover. Overtime, optics and LEDs face threats from contaminants such as outgas from fixture and and LED ballast components.
It is a myth that LED does not attract insect.
