I forget what exactly is on the interconnect red wire of detectors that have it. Std is 9v, I just not sure if that is dc or ac. But you could harness that signal to turn on something else.
RE: NFPA 72-2013 29.3.8.1
Does anyone know of a smoke alarm with a low frequency (520 hz) sounder?
Does any one know of a 120V low frequency (520 hz) sounder? (could be connected to smoke alarms via relay)
It's 9 volts DC. But you need to look at codes and regs to see if you can tap into it or not.
The problem with 520 Hz sounders is that these are actually speakers, not piezo sounders. That means they are real power hogs. You could never make one that was only battery operated. No one that I know of currently has 520 Hz smoke alarms.
Dont need to tap it. Just need e field sensor by the wire![]()
These meet NFPA 72 code spec :thumbsup:
520Hz, and not a speaker
http://www.ti.com/lit/ug/tidu994a/tidu994a.pdf
Not really. They are pigtailed in a box, so you push the 120 to one side, and keep the control wire on the other side, tape sensor to signal wire, hook sensor back to what device will alarm when voltage is detected on signal wire.The 9v signal wire is run in the same cable as the 120 VAC powering the alarm so a field sensor may be problematic.
Thanks for the replies.
The application would be a 1 or 2 bedroom apartment designated for hearing impaired.
Plan B is a small household fire alarm system 12V or 24V and use smoke detectors and AV alarms.
Use a bedshaker for sleeping quarters and a strobe accessory for waking hours.
What if they are blind?
You need items for blind and/or deaf people.
Bed shaker is a good idea.
Since the OP said "hearing impaired" I thought I'd try and break tradition and stay on topic.:angel:
