Never say never.
What?s Involved in Outdoor Lighting?
For outdoor use, 12 volt, 24 volt, 48 volt and 120
volt lighting are appropriate. A transformer is
necessary in order to convert 120 volt to low
voltage, such as 12 volt. Any wiring used for 120
volt lighting has to be buried in ground and secured
in a protective conduit. Twelve volt to 120 volt
lamps, wiring, junction boxes and con-nectors have
to be completely waterproof to avoid electrical
shock where water is present. These low voltage
and 120 volt systems must be installed by a
licensed electrical contractor and local permits
must be taken out before installation.
Under Connecticut law, the only lighting that can
be installed without a license are:
? pre-wired and pre-fabricated factory enclosed
transformers without any terminations or splices,
that can be plugged into an outdoor electrical
outlet previously installed by a licensed
electrician; AND
? individual solar-powered lamps.
From here
http://www.ct.gov/dcp/lib/dcp/pdf/2008_lighting__fact_sheet.pdf
How about in MA?
I see landscape contractors advertising landscape and holiday lighting.
