Lowest %Z transformer
Iron_Ben
Lancaster, PA
What is the lowest impedance you have ever seen in a pole or pad transformer? I dont recall seeing anything lower that 1.8%, but I am sure there are lower.
Off the top of my head, 1.7% for sure. When I would be poking around the yard looking at nameplates, the vast majority were 1.7 to 2.1 or so.
15-25 KVA pads and poles I have seen are 1.9-2.3. Impedance seems to go up as the transformer size goes up. This is surprisingly low for a 166. Its a submersible vault unit:
11bgrunt
Pragmatist
TEXAS
Electric Utility Reliability Coordinator
This is an autotransformer @ 1%
Certainly odd for me to see this.
mivey
I for sure recall 1.2%. Maybe 1.0x but I would have to look. Don"t ever recall one below 1.0
wbdvt
Rutland, VT, USA
Electrical Engineer, PE
That 77kA is NOT available fault current. That is the infinite bus fault current. There is a difference and it is important to keep the nomenclature correct.
The available fault current would be based on what the utility is capable of delivering for fault current. This would be then result in an available fault current on the secondary side which is going to less, sometimes substantially so, and will be less than the 77kA.
topgone
Correct. I plugged-in some numbers; assumed 1,000 MVA short-circuit power available at primary side, 300 feet of wires--> the available fault current I got was 74kA at the 208V side! I guess it is about that ballpark, IMO.
Yes I know
bwat
EE
NC
EE
500kVA pad mount at 1.9%
Two things.
1) That is crazy low for 500. Thanks for sharing that experience because I didn’t know they made them that low for something for that size.
2) We have strangely similar user names. I feel like I have to apologize to you since you joined long before I did. :)
