bure961
- Farmingham, MA
I have read here that wiring for low voltage led lights that is used for under counters can not be installed inside of walls unless its rated for such. Is there a low voltage wire rated for inside of walls or is it a practice to use romex ? We have seen the low voltage wire being used for under counter work but never able to see its rating.
Before we installed this ribbon type of led I like to be sure its being done correctly. In the passed we used fixtures for under counter use and romex was the choice of wiring. Is this something an inspector would look for in kitchen rework ?
