j rae said:can you use metal madison hangers on a plastic box?????
480sparky said:Does the box have any ears? If not, you can't.
480sparky said:Um, they kinda keep the box from falling back into the wall.
Rewire said:I always apreciate when someone says yes or no they back it with the code reference.
mdshunk said:I have occasionally used one Madison strap on a plastic nail-on wall box when the stud either twisted badly or was bumped out of position between the rough wire and the finish. This condition can sometimes cause the off side of the box to protrude beyond the drywall. I can normally slip a Madison strap in along that side to hold the box back flush.
dSilanskas said:Why not toe screw the box into the joist? It will hold the box from moving![]()
romeo said:We always called them madison straps. I say no unless they are bonded to the egc,just as a metal finish plate must be
1793 said:I'm glad to know that I'm not the only one to have ever done that.
monkey said:me three.................
Touching... interested to hear if others bond.jim dungar said:When you use madison straps with a metal box, do you bond yours to the egc, or to the box, or do you accept them simply touching the box as being effectivly grounded?
