ptonsparky
Tom
- EC - retired
I
Took to long to edit...stay tuned.
We can have the answer Googled before you get the question posted, I'll bet!!
I think there are too many details in the process that are left out to be able to answer.Raw Product Arrives at a set speed. Finished Product Leaves at a set speed. PA>PL
PL has a 3 minute head start on PA. What is the formula for raw product level to reach the start/stop point again?
How do you get a three minute head start on leaving when you haven't been processed yet?
Probably more a matter of asking the right question.
You wili probably ask for the name of conductor's sister!
Phil Corso
180509-1343 EDT
ptonsparky:
You need to know the volume between the two level switches, call it V.
Let Fo be the output flow rate, and Fi the input rate. Let Vover be the overfill volume.
Assume Vover is not large, then the approximate time to empty to low level Temptying = (V + Vover)/Fo.
On filling the time motor has to run is Trun = 3 minutes + ( V + 3*Fo )/(Fi - Fo).
So descriptively:
1. You have some change in volume between the high and low limit switches. This is V. You also have some overflow, and you imply this can be ignored, but it does have an effect on the time to get to the low level switch.
2. Once you get to the low level switch the filling motor starts, but it takes 3 minutes before it starts to add product to the tank. That is the 3 minutes in the run time equation.
3. Also during this 3 minutes the tank continues to have product removed. Thus, the volume that has to be added to reach the full limit is V + 3*Fo. That is the volume between the high and low limits plus the additional lost volume during the 3 minutes there was no flow into the tank after low limit was reached.
4. Now we know how much has to be added to reach the high limit switch, V + 3*Fo.
5. The time to add this much product is determined by the net inflow rate. That is Fi - Fo.
6. Thus, time to reach full limit is INITIAL DELAY + TIME to FILL.
TIME to FILL = Change in volume / Net fill rate (this is once filling starts)
See if I made any mistakes.
it will be a while before I can fill in the blanks with known values. Thank you all.
I dropped a "not" in the above, I meant to say that at time t=3, raw product has not run out yet, which is what the inequality signifies.At time t = 3, raw product has run out yet (I > 3 * PL), and new raw product starts arriving at rate PA > PL.
