Nobody wants to suggest a larger motor/pumpset?
The two formulations come out the same if the only pressure in the system is the static head pressure (due to gravity)
If you are working against a system pressure from other than gravity head you have to use the pressure times volume flow rate form.
Yes, but the system in question involves a pressure increase of 4000 pounds-force/inch² and a negligible elevation change.isn't 'HD" always a combination of dynamic/friction and static/gravity? ...
4000 lb/in² is comparable to pumping up an 8000-foot increase in elevation.
Easier with SI................makes no difference to the pump though
power = work/time
work = force x displacement
in this case
force = lbs of water moved
disp = head (either friction or elevation change)
time is derived from the rate lbs/time
Say you want to pump a fluid with a specific gravity of 2.0 up 10 feet. Would you say that the static "head" is 20 feet, or 10 feet? (Edit: not rhetorical, I don't know the standard usage.)
If the answer is unambiguously 20 feet, then "head" is just a unit of pressure tied to a vertical column of water at sea level. The direct analogue to the "mm of Hg" unit of pressure.
If the answer is ambiguous, then it would be best to clarify that the unit of pressure is "head of water."
Cheers, Wayne
Yes, but it's true....................you just had to go there!!!
:lol:
10 ft
the equation is then HP = (10 ft x Q gal/min x (2 x 8.34 lb/gal)) / (60 sec/min x 550 ft-lb/sec / HP x eff)
units cancel to HP
No, 20 ft. It's the equivalent water column.
Less error-prone, too.Easier with SI ...![]()
if we ignore friction and the pump is lifting vertically 10', I would call that 10' HD
I consider density a separate variable (as is gpm)
Consider all you like, but that's not the common practice in the chemical process industries and fire protection, in both of which I have personal experience.
When certain clients already have something, they are set on using it and can't always figure out why it is undersized for their needs:happyyes:Nobody wants to suggest a larger motor/pumpset?
I guess he wants to use feet (or meters) in his NPSH calculat ions, too. <g>
I guess he wants to use feet (or meters) in his NPSH calculations, too. <g>
