I am confused by parts of the code. As I understand it properly installed MC can be used as the EGC. This would then be acceptable to ground an outlet to a properly installed metal box if the outlet has no washer behind the screw. If so why does MC typically come with a ground wire? Or am I reading the code wrong? Could I pigtail from the Ground screw of an outlet to the box with only 2 wire system in the box?(if the box and MC/EMT is properly installed)
