peter d
- New England
How smart could they be to work for a cow??
I can't argue with that.
They dont have an aluminum oversized grounding conductor.
I wonder if the purple wirenut is rated for a grounding conductor or even the alumicon for that matter I would have to read the box. Maybe the I just read a gb greenie box and it is cu to cu only. 14-10awg 600v listed 63m2 ground connector. The purple wirenuts is a good idea by putting a piece of cu in there dont know if they are listed for grounding though.
i know it's listed, and approved..... but an aluminum bond sucks.![]()
Since it got intoduced, I have been waiting for this thread. I haven't used it yet myself, but was wondering how many local inspectors will try to require the bonding conductor become a "grounding wire" inside the boxes. I don't think the plastic boxes will fly- but I'm nowhere near my code book.
It is designed to be terminated both ways and I have installed it cut off however I am trying to forsee future isues if the ground wire which just happens to be aluminum creating all kinds of problems for the installer before I have a crew of guys installing it standing around hemming and hawing and not knowing what to do with it. It is always to your advantage to know more than one way to skin a cat.
It doesn't "suck" if you cut it off like it's intended to...it eliminates an EGC termination and saves time.
i understand what you're saying peter, it's an approved means and
method. saves time. i just don't much care for it......:smile:
and provides a nice aluminum conductor for the ground....
sorry, i'm just not feeling warm and fuzzy about aluminum
conductors for branch circuit wiring.
even grounds.
branch circuits in walls.... how about metal boxes, smurf tube, and
stranded conductors?
randy
At least I got through to one person. No one is paying atention to the fact that there are issues with code compliant instalation of plan b. Is a ground screw listed in the first place ?? And if it is is it listed for Al?? This stuff is going to be whored in just like any other new product and I need options. It is my job as a foreman /contractor to have all the answers without wasting anybodys money.The AHJ here has his own ideas about installing MCAP that are for the most part OK with me.
A rough in crew before me installed MCAP stripped back through ENT (smurf) to a metal ceiling box in the overhead poured deck. The conductors and the Al bonding jumper are coiled up in the concrete tight 4/O box. I'm with cow: What do I do to bond the 4/O box? At first I did not believe the Al could be used like this, but cow is right: The manufacturer says we can terminate the Al bonding jumper rather than cut it off (which is my preference). I wish the rough in crew had used regular MC with copper ground for the smurf runs.
And with that being the case, what is your feeling about HCFC?Roger
With the introduction of mcap into the field you are given the choice of either cutting flush or entering the box with it.
Where does it say that the aluminum "ground" wire is suitable for termination?
I have found nothing supporting that statement on the IAEI or Southwire websites.
Yeah that makes sense, go looking for trouble where there is none.
Cut the darn bonding strip off, it does not make it 'better' by terminating it. It passes all bonding tests with it cut off.
Of course all this will fall on deaf ears. :roll:
I happen to own such an instruction taken off the 1000' reel on the dashboard of my truck. I will gladly fax/email a copy to you as I have trouble posting pics as the reolution is too high and I dont know how to downsize them.
Sure, if it's from the product itself I would be happy to see it. I just find it strange that this information is nowhere to be found on their website.
