76nemo
- Ogdensburg, NY
electricalperson said:so if i get a bad reading on a piece of UF cable does it mean the cable is bad or is it because its in the ground?
Can you reword that again?
well that guy said that if you megger a uf cable thats been underground for a long time you will probably get a bad reading. im wondering if that reading actually means the cable its self is bad or if you get a bad reading caused by the ground and water and the cable is still good76nemo said:Can you reword that again?
electricalperson said:well that guy said that if you megger a uf cable thats been underground for a long time you will probably get a bad reading. im wondering if that reading actually means the cable its self is bad or if you get a bad reading caused by the ground and water and the cable is still good
480sparky said:Didn't someone post a video of doing just that lately?
frenchelectrican said:Ken,
Yepper i am sure if i nailed right BrianJohn did that and also have a photo i am not sure if he post it here but i know he did allready on other forum that i know for sure.
Merci, Marc
HighWirey said:frenchelectrician posted:
"MDshunk or myself ??"
My apology Marc, I will be more specific in the future.
Did not know you had to 'isolate' when using the thumper also. That is why we are all here, to share and learn.
Always located my voltage 'leaks' using the VOM 'probe de dirt' method.
Best Wishes Everyone
76nemo said:That, I didn't see. Where is it Marc?
Hey, that's a very nice demo. What was the applied voltage? e/mbrian john said:
electricalperson said:a thumper is used to find cable faults underground. the power company uses them if im not mistaken. they put a high voltage and it creates a short circuit underground and you use a hearing device to hear it underground.
