electrofelon
- Cherry Valley NY, Seattle, WA
A building where I did a service upgrade a few months ago had a fault in a feeder feeding a transformer. Presumably at about the same time, the 2 C phase conductors broke/melted off the utility transformer secondary terminals. Here are the details: 1000 amp 120/208 overhead to underground service. 6 service disconnects. One service disconnect is a 150 amp breaker feeding 3phase 3 wire #1 CU in 2" emt which feeds a 45 KVA transformer. The transformer installation is old and incorrectly done. Its a 240 delta to 208 wye used in reverse. The XO (now the primary side) had a neutral landed on it. I had to rework the conduit and pull out the conductors as part of the service upgrade and I did not reconnect the neutral when I hooked it back up. The secondary is ungrounded and has no ground fault detectors. The transformer feeds three AC compressors. The load is not very much, probably 50-60 amps worst case. So I get called in an find a hole melted through the 2 inch EMT, and one phase out. I look up the pole and the c phase conductors are just hanging there. The fault on the EMT looked like it was quite dramatic: There was a 2 inch long slot burned in and there is black spot on the ceiling and bits of black charred stuff everywhere. It looks like perhaps it started as an overload, or the fault took a while to clear. The fault was right at a coupling where leads to be think there was a burr on the pipe or nick in the insulation, but it is odd as it was a big pipe for three number ones and only 6 feet of conduit - not like it took any sort of effort to pull those conductors in and damage them. Then the conductors burning off the transformer terminal at the same time seems strange too. Any ideas as to the chain of events here? Ill post some pictures in a bit.
