Metallic conduit body between PVC runs.
Guys installed metallic conduit bodies between runs of PVC. Any solution to bond these other than drill and nut and bolt a lug to them? No clue why they didnt install EMT.
If you drill the body to install a lug, you end up with an issue of voiding the product listing. Perhaps a bonding U-bolt or bonding strap around the circular hubs might work, in which case you'd need a #6 bonding jumper running to a point where you can connect it to the EGC system.
