kwired
Electron manager
- NE Nebraska
- EC
I guess this the two examples from this T&B's product info would not meet code.
http://www.tnb.com/contractor/docs/sc_raintightemt.pdf
If you read page 2, you will see the following information about the T&B fittings.
Materials, Specifications
Material: Steel Body, Steel Locknut
Plating: Zinc Plated, Clear Chromate Coating
Liner: Nylon (for insulated fittings)
Threads: Male hub threads NPS
Use: Raintight, wet locations, concretetight
I don't see what any of this has to do with a myers hub. The Male hub thread NPS is specifications for the male end of the EMT fitting in the document.
