growler
- Atlanta,GA
Ok, thanks. Would you need an extension ring as I would imagine you would have the sheetrock and millwork giving you about an 1-1-1/2'
If I understand what you are talking about the answer is no.
You use an old works box. Not as much room as 1900 box and extension ring. But it can mount without having a stud for support. Depending on the amount of room you could use a deep metal old works box and extra length madison bars ( same company that make the template).
The old works box fit into the hole that's cut and is flush with the surface of the millwork. Ears keep it from going in to far and the madison bars keep it from pulling out.
