min. height of disconnect
w.fune
mccook, NE
does any one know of a code applying to how low aequiptment can be mounted? living in Nebraska snow is a corcern. Everyone I talk to tells me something different. thanks
Smart $
Esteemed Member
Ohio
There's no minimum height as far as the NEC is concerned.
Ponchik
CA
Electronologist
I don't think NEC has a minimum height. It may be a local issue in Nebraska.
Sorry I wasn't much help.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Just put it where you wouldn't mind working on it with 2' snow on the ground. I saw one service that was 3 inches off a deck with a flip up cover to boot. Obviously the deck was added..............
acrwc10
Master Code Professional
CA
Building inspector
Only minimum height is for Mobile Home Service Equipment, in 550.32(F).
Reasons? Floods, snow, dogs, not sure...
Never thought of "Dogs" as an issue but now that you mention it, do they have more dogs around mobile homes than any other type of home?
If it is a utility disconnect they may have a minimum hight, ours does.
resistance
WA
Interesting, I just seen the same thing a couple months ago, and yes the deck was added. Are you following me:eek:
