Fmkehoe
- Cornwall ny USA
- Inspector
Doing some work on a house and needed to go into the circuit breaker panel.
I see the conduit coming in from outside from the meter pan and I notice there are two, 4/0 cables and that’s it. No neutral.
I go out to the meter and look up and sure enough, there are the two cables and a neutral going into the weather head from the pole, down to the meter, but no neutral from meter to panel. Only a bare copper cable in the circuit breaker panel going thru the wall and onto a ground rod outside.
Am I having a stroke or is there something curious here ?
