kenaslan
- Billings MT
MOV and space heater inside of the skid. Electrical has yet to connect to the Single Point Connection
I was tempted to poke fun at you on how particular you said you were when making up such things yet you can't even spell some of the components correctlyI just noticed I've been spelling DIN rail with an e instead of an i
My bad.
JAP>
I'm glad you didn't.
I know you're in the farming community,, I'd come charging at you with a bindicator if you did that.
JAP>
Wonder how many that participate here know what a bindicator is? I'm talking original product that has bindicator as a trademarked name, there may be other items that get called that at times, as well as other items from same company that have that name associated with them.
Seems you do know what they are then.And yes I did mean the roto type.
JAP>
This IS what came from the factory. Besides, Oil drilling facilities are BEYOND cheep. Considering a drill site has a life of less than 30 years, they don't care. But who knows, Technology keeps improving. Rod Pumps, Gas Lift, Submersible pump, Fracking
Do you know what a "Stirrator" is or a "Shivvers" system? Both those becoming things of the past, how about more modern "power sweep"?
My vote for the longest unbroken sentence on the forum.My 1st day on the job in my electrical career was on top of a grain bin installing a bindicactor with the motorized paddle. Then onto the limit switches for the indicator lights in the distributor head on a 130' grain elevator then to the vibrators to rattle the stuck feed out then to the pulse socks on the dust collector then to the controls for the cyclone blender then to the shaker for the fines and overs then to the size 5 soft start for the pellet mill then to the controls and interlocks for the auger under the mixer then to the load out auger under the scale then to the mollasus blender then to the air compressor controls then to the size 4 starter for the hammer mill then to the to the ....... oh well you get my point.
Or inhale if they're reading aloud.It keeps people from having to scroll down.
Many terminals are rated for more than one wire. Sometimes it just takes a little digging to find the right document.
Not familiar with the cable in question, but something tells me the three together must be used as one EGC - so that sort of makes it one conductor? Kind of like the concentric bare conductor in SE cable or other similar cables.
They appear to be smaller then the insulated conductors on what looks to be less then 10 AWG, but not really certain what thickness of insulation is either.
I know what a Bindicator is, but not the others. Bindicators are used a lot on the aggregate industry too.Seems you do know what they are then.
Some types of MC cable utilize the metal jacket plus the undersized copper conductors to make up the EGC. If I was doing it just to be sure I would use a grounding bushing on the cable connectors and include that as part of my ground path. If the cable would ever short to the metal jacket there may not be a low impedance path to trip the over current device, which could allow the metal jacket to remain energized. Could be lethal if some one were to touch the cable and come in contact with the jacket. On some types of MC cable those undersized ground wires may be spot welded to the metal jacket. Follow the manufactures recommended instructions.
Type MC-HL cable has 3 ground wires. Do you think this is a code violation? Or is it ok to twist together and land.
