winnie
- Springfield, MA, USA
- Electric motor research
slip = current? :?
For a common 'squirrel cage induction motor', when the rotor is rotating in perfect synchronism with that magnetic field, than it 'sees' a DC field. No current is induced in the rotor, and there is no rotor magnetic field to interact with the stator field to produce torque.
As the rotor slows down, the 'sees' an AC magnetic field. Current is induced in the rotor, which produces a rotor magnetic field, which allows torque production.
'Slip' is just one way of describing the difference between rotor speed and synchronous speed. It goes from 0 (synchronous speed with zero torque production) to 1 (locked rotor). (Actually slip can range from below zero to above 1...below zero means a 'plugging' motor, meaning one spinning against the drive direction. Above 1 means a motor operating as a generator. Normal operating region is very near 1.)
The greater the slip the greater the induced rotor current, at least in the limit of less than 'breakdown' torque. Motor current consumption goes up as rotor speed goes down, but I don't know if rotor current goes up monotonically.
-Jon
