Move Ceiling Light Fixture
learning101
Always learning
Arizona
SCOPE
Customer wants to move existing ceiling light fixture roughly 4 feet over from the existing location to be directly over the kitchen island.
PROBLEM
Customer does not want to have the existing fixture box on the ceiling once a new box is installed over the island. Obviously, the wiring is going to be roughly 4 feet short to the new box. Because the customer does not want the existing box to remain in the ceiling, there's no place to splice the romex to get it over to the new box.
PROPOSED SOLUTION
Cut a number of access holes in the ceiling to trace the wires back from the existing box to an origin of splicing in an accessible box or at another fixture/switch. Then run a new 12-3 romex from an existing splicing point.
Is there another solution recommended opposed to what I've recommended?
Photos of ceiling and existing light fixture can be seen here---->Kitchen Island Light Fixture
So they want to get rid of the swag? They already have a blank in the ceiling.
I don't like these but as far as I know they are compliant.
View attachment 2561510View attachment 2561511
Best solution I was using these frequently for years and their great. They are just hard to come by now, normally cost around $8 each since the pandemic about $24 each if you can find them.
Given the two options, I'd take the Tyco type of splicing device over the buried wirenut splice.
Just curious, if you were going to "bury" the splice anyway, why would you choose the Tyco over the wire nutted in a JB splice? IMO, the JB would be safer, I know it would be cheaper and faster.
I wired a basement 5 weeks ago that had bunches of j-box splices in the ceiling.
Where I was able, I moved wires to accessible points and installed new j-boxes.
Where I couldn't move adequately, I used Tyco splices. I used 5 of them, and 2 did not have good connection to the wires even though there was a definite click when closing the lid.
From a practical standpoint, I would much rather bury a Junction Box. But I do it the approved way.
As far as time, it's kind of a wash either way either way. I've gotten pretty quick at those splash kits
Every time I've used one, I put on my magnifiers and push the wire into the crimp with a pair of needle nose and make sure it all looks nice and biting and then close the clam shell.
