bobbymari
- los angeles ca
Hello all
we recently put in a multimeter section on rear apartment building. There is a detached front house that owner is requesting us to feed overhead. Typically we go underground to detached bldgs but asphalt was just repaved so he doesn’t want any patching.
Its been a while since I’ve done overhead feeders so just want to check if there are any new codes I may be missing. Clearances over bldg and driveways can easily be met and plan is to feed the 100 amp panel with 1/0 quadruplex. Approximately 70 foot span.
Anything else changed in overheads other than clearances and wire size?
Thank you
Thank you
