ceb said:I agree that IF the elect. has kept good records you could get by with flat rate pricing. However,have we not all looked at a job and in our mind from experience said it should take me x# hours only to run into something we could not see and it winding up taking xx# of hours? Now if you have flat priced the job you loose.Then on the other hand every thing falls into place you win. I think you would loose more often than win.But with the plumbers $1200.00+ to replace a toilet, pipe is already there, two bolts ( worst case need to cut with saw ) one water line, replace wax seal, two new closet bolts, reconnect water line not a lot of hidden obstacles. I would only want to replace two toilets a week for that.:grin: No I'm greedy four:grin:
you rarely lose...like anything else, if and when you run into issues, you let the customer know and proceed from there. sometime you change the scope of work (and the price)...sometimes you simply do a completely different install...it's no different than giving a fixed price bid on a larger project...
or is it better to take a lower rate at T&M and let the customer take all the risk (and reap all the reward)?
