mivey
I'd be curious to see if it worked. Then we could just solder that conduit together.:grin:tmbrk said:I know what ya meant, I was just kidding.:grin:
It's just not something you'd use on EMT.
480sparky said:What is ?
jflynn said:The fitting,-as noted in post #2,- is this not a EMT to greenfield fitting?never seen one like this used with EMT,is this fitting compliant as used?If so I/ve learned another one...
480sparky said:That's why I asked... I didn't know specifically which post you were referring to. It helps to quote the post you are speaking about.
jflynn said:Why would I be referring to any other post?my post #31 was under the heading "name that fitting"--my bad I will try and do better...
mivey said:I'd be curious to see if it worked. Then we could just solder that conduit together.:grin:
