Name That Fitting
tmbrk said:
I know what ya meant, I was just kidding.:grin:
It's just not something you'd use on EMT.
I'd be curious to see if it worked. Then we could just solder that conduit together.:grin:
480sparky said:
What is ?
The fitting,-as noted in post #2,- is this not a EMT to greenfield fitting?never seen one like this used with EMT,is this fitting compliant as used?If so I/ve learned another one...
That's why I asked... I didn't know specifically which post you were referring to. It helps to quote the post you are speaking about.
Why would I be referring to any other post?my post #31 was under the heading "name that fitting"--my bad I will try and do better...
Well, here we are 46 responses into a thread, and when I read your post, I thought you were referring to my post #29 or masterinbama's post #30.
Please don't take this as an attempt to publicly humiliate you. That is far from my intentions. And this is not only for your benefit, but for everyone here. I just helps out a lot to specifically know which post you are referring to.
So to summarize the Bridgeport 282-DC fitting is listed for coupling 3/4" EMT to 3/4" FMC. The 1/2? EMT to 3/4" EMT transition is a creative violation.
Category: EMT Conduit Fittings
Catalog ID: 282-DC
UPC Number: 78174709282
Description: Coupling, Combination, Zinc Die Cast, Flex Size 3/4 Inch
Application: Used to join EMT to flexible metal conduit. 282-DC is squeeze type for flexible metal conduit. Set screw type for EMT end.
Trade Size in Inches: 3/4-3/4
