KeithAdams
New member
- United States
The width of working space can be shared between electrical equipment. My question is, in order for the width of the working space to be shared, does all the equipment need to be front aligned? For example, for the working space above and below, electrical equipment can protrude up to 6".
Here is the situation...you have a disconnect switch and standard panel mounted side-by-side on a wall. The disconnect switch extends 8" from the rear wall with 28" from the side wall to the edge of the panel. The panel extends 10" from the rear wall and 50" from the side wall. Can these two pieces of equipment share the working space?
