DGomes
- Pawtucket RI, USA
- Electrician
Do Commercial washer machine in a commercial laundromat require GFCI protection per NEC 2023? NEC 2023 Article 210.8 list dryer but not washer. Does any one know why that is?
Isn't GFCI protection required for laundry areas? I think that would cover a laundromat.NEC 2023 Article 210.8 list dryer but not washer.
Yes, I agree . But the fact that they added dryers to the list of appliances that requiresIsn't GFCI protection required for laundry areas? I think that would cover a laundromat.
Shhhush, don’t tell them hard wired washers existCommercial washers have a variable speed drive and GFCI may not work
If the washer is connected to a receptacle it is required that the receptacle have GFCI protection. Makes no sense why hardwired washers wouldn't have the same requirement.Yes, I agree . But the fact that they added dryers to the list of appliances that requires
GFCI and not washers just makes me wonder if there is reason why. 3 phase or single phase Commercial washers have a variable speed drive and GFCI may not work.
A dishwasher needs gfci protection even if it is direct wiredYes , if a washer is connected to a receptacle it is required to have GFCI protection. I agree . But what difference does it make ? Shock hazards exist wether an appliance is hard wired or cord - and plug connected.
NEC 2023 . 422.5 (A) (3) list cord-and-plug connected high -pressure spray washing machines, vending machines ,dryers etc..If I hard wired all the above I still need to provide GFCI protection.
GFCI protection shall be provided for the branch circuit or outlet supplying the following appliances rated 150 volts or less to ground and 60 amperes or less, single- or 3-phase:
- (1)
Automotive vacuum machines- (2)
Drinking water coolers and bottle fill stations- (3)
High-pressure spray washing machines- (4)
Tire inflation machines- (5)
Vending machines- (6)
Sump pumps- (7)
Dishwashers- (8)
Electric ranges- (9)
Wall-mounted ovens- (10)
Counter-mounted cooking units- (11)
Clothes dryers- (12)
Microwave ovens
For whatever reason the NEC doesn't care about hardwired washing machines being GFCI protected.Yes , if a washer is connected to a receptacle it is required to have GFCI protection. I agree . But what difference does it make ?
No worries. we are talking about clothes washers in other than dwelling applications. commercial laundromatMy bad I thought we were talking dishwasher. Sorry I am out of it the last few days--
Yup 210.8(B)(14) applies to laundry areas in other than dwelling units . I would think a laundry mat fits the description lolIsn't GFCI protection required for laundry areas? I think that would cover a laundromat.
210.8(b)(14) address other than dwelling units gfci protection of receptacles in laundry areasA dishwasher needs gfci protection even if it is direct wired
D) Specific Appliances.
210.8(a)(11) addresses the gfci protection of receptacles in dwelling unit laundry areasYes, unless hardwired
see 210.8(B)(11) for receptacles
The clothes dryer was added to 210.8(D), the expanding list of appliance outlets, which includes hardwired
We are both correct.210.8(a)(11) addresses the gfci protection of receptacles in dwelling unit laundry areas
210.8(b)(14) addresses gfci protection of receptacles in other Than dwelling unit laundry areas , which is what’s applicable here
How so when you incorrectly quoted the code number . 210.8(b)(11) is in reference to gfci protection of receptacles in other than dwelling unit crawl spaces at or below grade level . That has absolutely nothing to do with gfci protection of receptacles in laundry areas in other than a dwelling unit . You are in no way correctWe are both correct.
And 210.8(d) has absolutely nothing to do with this post .We are both correct.
Grasshopper has much to learn about code cycles.absolutely nothing to do with this post
I believe (D) addresses both dwelling and non dwelling.210.8(b)(14) address other than dwelling units gfci protection of receptacles in laundry areas
