Does ceiling height come into play?infinity said:There requirement is for a fixture that is listed for a wet location if subject to shower spray.
Won't the resultant precipitation fall?cowboyjwc said:If the water starts to mist and cool down, when it gets on that hot bulb you might wish you had an enclosed trim.
And who gets to determine when shower spray comes into play. If you shower the water will certainly slash some so-- at what height as Larry asked, would it not come into play. NEC doesn't seem to address this issue-- or does the code mean when water hits the fixture directly?infinity said:There requirement is for a fixture that is listed for a wet location if subject to shower spray.
I understand I could do that but you know the HO probably will not change the bulb with a par lamp.infinity said:I wouldn't really worry about the lamp exploding. IF this is a concern then you could use a PAR lamp. I have these all over the outside of my house that receive a direct hit form the rain. Even have a few tree lights with the PAR lamps aiming up into the rain, and at times they're buried in snow. Never had one explode.
LarryFine said:Does ceiling height come into play?
Where did you get this info? What article?360Youth said:I beleive the zone is 8' high by 3' wide, from the rim of the tub, that any fixture has to be wet location and non pendant or is it just non-pendant?
Open trims are allowed outside on porches> I install them all the time, as long as the can is and trim are listed for damp location. Most of the halo recessed cans and trims that I am aware of are listed damp location.360Youth said:As to the open trims, if it is UL listed for the application....I have seen numerous open trims installed outdoors on porches. I did not think this was allowed either.
Dennis Alwon said:Where did you get this info? What article?
410.4 (D)
Dennis Alwon said:I understand I could do that but you know the HO probably will not change the bulb with a par lamp.
360Youth said:I guess what I was asking was the dimension of 8ft and 3 ft does not mean it has to be wet location. The last sentence refers to any light fixture in the zone has to damp location listed unless it is subject to shower spray. An open recessed can can be acceptable over a shower because they are (can be) damp location listed. If it is subject to shower spray then it must be wet location listed. The question was being asked at what point above a shower does spray not come into effect? or how does one determine the spray zone?Dennis Alwon said:Where did you get this info? What article?
410.4 (D)
infinity said:There is no requirement that any fixture within the tub zone (8'X3') be listed for a wet location. A damp location fixture is permitted if it isn't subject to shower spray. I don't know about you but I have never sprayed the ceiling above my shower with the shower.
Tell that to Shaq. Tall people can repel high water pressure, Not likely, but how much of the NEC is likely??
Dennis Alwon said:360Youth said:I guess what I was asking was the dimension of 8ft and 3 ft does not mean it has to be wet location. The last sentence refers to any light fixture in the zone has to damp location listed unless it is subject to shower spray. An open recessed can can be acceptable over a shower because they are (can be) damp location listed. If it is subject to shower spray then it must be wet location listed. The question was being asked at what point above a shower does spray not come into effect? or how does one determine the spray zone?
As the owl would say, "The world may never know.":grin:
