- Massachusetts
So in my own basement I have a sump pump that must work during certain times of the year, other times the sump is dry for months at a time.
This is the kind of pump I am using.
The problem that has now happened three times is that during the dry time the shaft gets tight in the bottom bushing. I have to pull the pump out, open the impeller housing and turn it by hand a bit then I can get the motor running.
The only reason I have not burned up the motor yet is because I do check the pump pretty often and had gotten in the habit of manually running it dry for short periods of time. I will let too much time go and when I try it out it will not turn.
So what I am thinking (I am open to any suggestions / mickey mouse ideas as long as they are cheap.
) is setting up a timer that will run the pump maybe 15 seconds every few days or a week not really sure how often. I don't want to kill the pump over doing it either.
Anyway this being in my own home codes and listings are down low on the priority list, function over form is fine.
TIA, Bob
TIA, Bob
