Jerrymosier
- Georgia
- Housing electrician
I am the electrician at the University of Georgia, and in my past experience we did things by code because it was always required, we knew it and did it. Sometimes we didn't know the exact code reference for each things so when I see issues, I have to go back and search to get the right section in NEC showing things are a direct violation. We have no inspections on campus, so various contractors know this and do whatever they want as well some internal electricians. I discover things constantly, hence the term if you look for water you'll find the ocean.
This brings me to yet another issue I discovered yesterday. All of our resident units whether it's a small unit or full on apartment/townhouse has an MDP then the units have individual panels inside them (main lug only). Those panels are what feeds each apartment/resident unit. I opened up one yesterday to check a circuit that was tripping and found the issue. I tried to upload the pic but it won't. The issue is it's a single phase panel fed with 2 1/0 A/B phase conductors and a 1/0 neutral and no ground. There is a grounding bushing and on there is a #6 wire (phased green....I know) and it's directly connected to the ground bar.
So this is a sub panel fed from an MDP with no EGC pulled into it. Can someone please direct to the proper section in NEC that will show that this is incorrect? I need to forward this up administration for correction if so. There could possibly be over 200 units that will need this done on so it's a major problem provided I can show the violation in code.
Thanks for any help
Thanks for any help
