Actually, the stops can be anywhere in series on the hot side of the coil... the main thing is, which you were correct to point out, is that the momentary switch parallels only the aux n.o. contact. I missed that because I got stuck in "drawing mode only, and forgot about circuit evaluation.K2500 said:...Stops should be in series ahead of reset/starts, so that the PB must be reset before anything starts moving again...
Which takes us to where the momentary/aux switching portion of the control circuit could be put ahead of the PB's such that there are no hots going to either PB in "shutdown mode".
