- Windsor, CO NEC: 2023
- Hospital Master Electrician
Re: Neutral on the ground bar?
Jhr, that was funny.
Scott, you've never seen a defective breaker? I've seen one (and only one) on a brand new service. It was less than a year old, but when the sun was high and shining on it, while it was loaded to around 40% capacity (because we turned everything in the house on), it would trip in the middle of the day.
Never say never.
That said, Rexmaster, you shouldn't be working on your friend's house. You're allowed to work on your own house, most likely, but you're probably breaking the law in your actions.
This "problem" you brought here is one of the primary life-safety systems in that house. If you had removed the item that you didn't understand, you would have set up the means to kill someone. That is not an exaggeration at all.
Please quit while you're ahead.
Never say never.
