mbrooke
Batteries Included
- United States
- Technician
I am gonna give you the benefit of the doubt and believe that you are not saying that if there is a voltage potential between two points there will be “ current flow”, I think you mean that the voltage potential must exist for the possibllty of “ current flow” to occur.
Always do- yes- the second one. Current can not flow without voltage.
open ckt
touch h-g
touch n-g
is the a difference?
is g/earth considered 0 potential?
Take a volt meter L-N- does it not read 120 volts?
N-G, Unless there is no load, there will be up to a few volts potential due to the voltage drop across the neutral.
But going back- if the neutral has no potential as you said, it could not read 120 volts, correct?
