tbonse
- South Carolina
Sanaka,
I think a better way to look at this is that each of the wires is a reference point rather than an actual voltage. The distance between any two reference points is our effective voltage. For consistancy we will refer to the neutral as our 0 volt reference point and leg A as our 120 volt potential, and leg B as our -120 volt potential. If you measure between Leg A and Netral, you will measure 120 volts, and if you measure between Neutral and Leg B, you will again get 120 volts, but if you measure between Leg A and Leg B, instead you will measure 240 volts.
Next, lets say you connect both sides of a 240 volt circuit to the same leg (ie Leg A), well now when we measure between Leg A and Leg A (2), we get a result of 0 volts. In the case of a Dryer, the controll circuits (which connect between Leg A and Neutral) will receive their expected voltage of 120v, where as the heating elements (which only connect to the two legs and not the neutral) will form a circuit between wires of equal potential (120v - 120v = 0v), which will not induce the flow of electrons (ie current).
