I am reading 2.8 volts A/C between the aluminum I-beam which is attached to my boat lift motor and the water below. I read the same even with the service main in the off possition. (No power beyond my service main breaker.) I feel certain that the voltage that I am seeing is coming in on the utility neutral but I have not had the utility neutral disconnected from the service to check it. I allowed the utility engineer to steer me in another direction when I should have insisted on disconnecting the neutral from my service but anyway.. His reponse was What will that prove? I plan on inviteing the utility guys back and verifying this but with that being said, assuming the voltage is actually coming in on the utility neutral, I was thinking that if I could convence the utility company to drive additional ground rods at the base of the utility pole the voltage should decrease as the resitance decreases.. Any thoughts or suggestions?
