mivey
Because 3 volts is your NEV and you are not bonding well to it everywhere.Yes that will get all the concrete to the same potential but not the water. Why the voltage when the bond is connected but not when it is disconnected? Seems the voltage would still be present in the concrete if it was ground voltage.
What is the current in your bond wire at the one end?
