iwire said:
Other than being a violation of 310.4 I can't think of any real issues that will become of it.
There is a certain part of my cerebellum which tells me to flight rather than fight on this one, but what the heck? I think by now the players on the forum know me well enough to know that is not in my composure.
The concept here is to avoid creating electromagnetic fields that are not cancelled by conductors carrying the counter field from any particular utilization equipment.
Specifically, the idea is that if you have a current supplying a load, you want the return path (all of it) to be as close to the conductor supplying the load on the line side as possible.
Footnote: EC&M has an article in a recent issue regarding theories that EMF (electromagnetic fields) may be causing some forms of cancer in younger folks' bloodstreams.
That said, NFPA 70 insists that current to any load must be returned to the source via conductors in the same conduit or cable supplying the load.
Forgive me if I get up on a soap box on this one. The problem arises if either the line or the neutral has more than one path from service to load, or if either conductor is separated from the other by some nontrivial distance. The concept is that the electromagnetic field generated by the current to the load should neutralize itself by virtue of the fact that all conductors serving the load shall be contained in the same cable or raceway.
Regardless of any anomalous behavior of the load, the net magnetic field around the branch circuit conductors must always be zero.
One of the typical violations of this arrangement is to provide two or more branch circuits from the service panel to a multigang box next to, say, a front door. The box has branch circuit conductors for the front porch lights, the living room receptacles, and a chandelier, for example. The electrician decides to tie all of the whites together with a gray wire nut. The box has a 14-2 feed from the panelboard for the lighting circuit, and a 12-2 feed for the split receptacles in the adjacent living room.
Dan
